Door blend actuator motor power clip.
Chaznsc
SC
Ive got a DBA clicking away in my 07 mustang. So im testing the 3 i can get to and managed to lose one of the little plastic clips on the power connection. It seemingly vanished. Will this prevent the DBA from functioning? Attaching a pic of one of the clips.
I also need to know where I might could find a replacement.
493 scamp
Kirkwood,Illinois
If it is a connector assurance clip, in my opinion they are worthless and a complete waste of time and material. Most of them I deal with under the hood are stuck,break,and are hard to remove after they break. If it is to separate or keep wires from pulling out of connector then you need to replace. I do not have a source other than new connector or rob one from salvage yard for them in either case. The old one is probably under the carpet or seat,that is where things run to that I loose. lol
C
Chaznsc
SC
@493 - thank you for responding. They are definitely an assurance clip. Nice you remove the red clip there is a secondary clip to press to remove the harness. Pain in the *** unless you are 18" tall.
I will keep looking for the clip, but appreciate the response.
