Door channel drain in cold climate?
Orionrising
Western Maine
My driveway is old and needs to be replaced at some point as it's a bit above slab at this point, and in late winter as the ice melts is runs into the garage. I am doubtful a hurricane strip on the door would be enough. Considering 3 options, cut out 1st foot or so
and fill with rock an drain tile ( not sure I like this one could cause slab heaving maybe)
Or form concrete lined Swale tipped.
Or install a channel drain, but I am not sure it wouldn't just fill with ice.
Sent from my Moto G (4) using Tapatalk
thickhead
Connecticut
Does the driveway pitch left or right in front of the garage or would the melt off just puddle in front if you put in a very low curb?
I like your idea of the concrete swale
I wouldnt want the melt off running under the garage and freezing at night like may happen if you open up a trench drain in an old driveway. If you could force the water to run on the surface that would be better where you are, no?
