Ancient Iron
I bought my wife a Ring Pro Doorbell for Christmas and installed it as per the directions. It worked fine. After about a month my door chime (I am sure it's original to the house built in 1955.) started to buzz and the plunger was pulsing.
I went to the transformer (NuTone 16V 30VA Which is the spec for the Ring bell to operate on) in the basement and noticed it only has two wires to power it black /white no green ground wire and it's mounted to a junction box with a light socket. Prior to mounting the Ring Bell everything worked fine.
My question is should I buy a new transformer with a ground and see if that works, I'm Thinking that since the new Ring setup is Electronic that it might be sensitive to grounding????
I'm running out of ideas
