Door choices….help
alex2929
I need a few doors for a bar room inside my shop and also a closet. I will probably use exterior doors so they’re insulated some and seal up good from dust and stuff inside the shop. Menards….lowes….else wear???? I want something that will last but feel like they will have an easier life being inside? Trying not to break the bank….this while project already has. 😂
readhead
Durango, Co.
Are you going to remove the thresholds? Seems like interior solid core doors with seals would be a better choice.
A
alex2929
I guess I did t think about this. What’s my best option? This is going on a concrete floor
K'ledgeBldr
Johns Creek, GA
Are the “few doors” all separating the bar from the garage/shop?
Then exterior jambs/thresholds with interior solidcore doors- or just those that do the separating.
A
alex2929
54x100 building.....I put a wall in so I have a 54x56 fixed up area. I will have a door from the shop to "cold storage".....also a door from the bar room to the fixed up shop. I will keep the bar room fairly temperature controlled......heat and AC. The shop I will only keep minimal heat in through the winter unless planning to be out there. The third door would just be for a closet that i have below the landing for y steps that go to storage above my bar room. any thoughts or ideas would be great.
A
alex2929
