Door for dead-on 80" rough opening?
Blackmesa
So I'd like to replace the door leading from my house into the garage. The door itself is 32"x78" and the rough opening is 34.5" x 80". The 80" height is dead on, the problem is that all the common Home Depot Jeldwen doors list a rough opening of 80.5". To make matters worse, they are packaged at the store with the trim pre-attached so I can't get a good measure on it.
Does anyone know if the Jeldwen doors actually require a 80.5" opening? If so, where can I get the appropriate size door, preferably fire rated?
superdutymike27
SE Wisconsin
Why not just leave the existing casing and jambs and buy a new door slab? You may have to rout or chisel for the existing hinge pattern on the new door. You then would be able to cut the bottom of the new door to size making sure you measure from the bottom up.
Seems like anytime you replace an existing opening with a prehung door problems arise with out of square openings or not enough room as you are dealing with.
I would try a local door supply company or lumber yard.
Just my thought.
CJ7VFR
Central New Jersey
Just my thought.
2X!
I am doing this exact thing for my front door.
My wife wants a door with a window in it (current door is a solid 6 raised panel door) to let in more light to the front hallway, and I didn't want to go thru the hassles of ripping out all the old door jambs, all the trim and the threshold.
I just wanted a door slab that was not pre-drilled for the door knob and deadbolt, and that also was solid wood with a 6 pain window in it.
That ended up being quite a challenge in itself!
Most places sell the doors pre-hung and they are quite expensive.
I finally found a Jeldwen door slab at Home Depot that fit the bill. Here is the one I bought:
This door is a 36 x 80 size. The nice thing about this door slab is that it has a two raised panels in it, so it still matches my existing back door and door to the garage. It will only take a tiny bit of trimming on the bottom and sides of the door to get it to fit into the existing opening, and I can drill out the doorknob and deadbolt holes to match the existing doorjamb.
It will probably take just as much time to prep this door and install it as it would to do a pre-hung door, but with a slab I don't have to remove and repaint all the trim, especially around the inside of the door since I don't have any of that paint left!
Jim
engineer031
Ontario Canada
go to your local lumber yard and buy a 32x78 door slab and it will fit right in. The door you bought is too big and will require cutting down, they do make 32x 78 doors
BDT/NWMN
Erskine, Mn
Sorry to mention building codes,, but a door between the house and an attached garage which is occupied by vehicles would need the proper fire rating in many localities..
Something you may wish to ponder before making any purchase
