98layinframe
- Joined
- Dec 6, 2014
- Messages
- 11
First off would like to say hi to everyone as I just signed up recently.
I have multiple questions for you guys since I'm currently building an addition onto my garage. Now that I have the garage framed in and closed up I'm starting to work on the door installation... and that's where my questions lay. First thing I noticed is the concrete guys poured the door step down a little uneven and the left side is about 3/8" lower then the right side. No big deal, but do I install the door with the lower panel sitting on the floor and then add the tracks in slightly parallelogram shaped? OR is the correct thing to just shim the low side of the door and space the track up so its level, then install everything perfectly level? (which is what Ive done so far.) The rubber seal is more then thick enough to close the gap to seal the opening on the low side, Im just worried about every time the door closes if its going to try and relax and shift itself in the opening.
The door is a 9'x9' with a 36" high overhead track and torsion style springs... So knowing the cables are tied together up top on the rod/drums will hold it level but its still something small that has me wondering.
