Door opener for super low headroom?
PCustoms
VT
Door has traditional extension springs. Previous install had notched the joist to accommodate the opener rail, this has since been removed and damage to joists repaired.
I installed low headroom brackets at the top of the door so that I had enough room to strap and drywall the ceiling. There can be more then 2".
I think the only option is a side opener, do those exist with extension springs?
Even this will be right due to width of door vs. width between concrete wall and main beam on opposite side.
CombatNinja
Traditional extension springs don't have that length of pipe or 'axle' or whatever you want to call it that a jackshaft opener winds up, so how is it going to work? I think you would have to convert to an overhead spring.
P
PCustoms
VT
Yeah, that's the question/issue.
Frankly I don't think I have the headroom for a torsion spring. It's that tight.
Leaflessshadetree
Don't ask.
Are you saying no more than 2"? Unfortunately you may have been better off leaving the opener recessed. Even if it required a different repair to the joist or replacing the joists with rafter ties.
AndyL
Vancouver
Pics would help.
Typical trolley Opener mounted beside the track has been done more than once in this type of scenario.
Just linking to the one commercial offering I remember - there's a few options out there.
P
PCustoms
VT
Correct.
I could not leave the previous install, these are floor joists with an occupied room above, there was a lot of bounce. Sistering the joists and replacing blocking firmed it up
Pics would help.
Been out of town, was waiting around when I posted this thread. I'll get some pics tomorrow night, but this looks like it may work.
Awag
SE NE
You can use a side mounted trolley opener on torsion springs but generally a door with extention springs will bind when being pulled from the side.
mike93lx
Richmond, VA
I had a regular belt driver opener on a 7' door with ceilings at less than 7'6". Worked fine. The guide for the belt was essentially against the ceiling
captaindiode
NC
I was researching something for my basement and found these:
Haven't pulled the trigger yet, so no direct experiance.
