Door Questions For New Garage
kngelv
Detroit, MI
I finally got the city to give me a permit for an additional garage. It will be 24' x 24' with 11.5' - 12' ceiling height. I planned on doing an 8' x 18' door. Today a buddy suggested I go with a 10' door height. Any reason to go with this instead of the 8' door. My attached garage has a 7' x 16' door with an 8.5' ceiling. I have a 4-post lift that we use to work on vehicles. The lift will go to the new garage. I'm also debating man door location. I can either have it in the front next to the main door or on the left side toward the front. Any reason to choose one over the other? Thank you.
James
BillK
Beautiful Southern Maryland
My attached garage and my 24x24 detached both have 16x7 doors. I honestly can imagine needing more than that ? Unless maybe you are working on some lifted trucks ? Not sure if I would even want the 18 ft width.
racecougar
Missouri
IMO, if you know that you'll never need the additional height, there are some upsides to the shorter door: less protrusion into the room when open, less heat loss, less cost. I went with 8' doors on my building years ago, and I have zero regrets.
dcg9381
Austin, TX
Depends on what you're putting in it. Standard residential doors here are 7' and the "option" is 8'.
Modern trucks (and Jeeps) - they're getting close to that 7' height. For residential I always opt for an 8' door.
Even with the 8' door, I'll admit to having wacked a flag on the back of the Polaris.
And then there is the time where I learned a GJ rule: "garage doors ALWAYS all the way up or all the way down".
I ran the truck camper into my shop door that I had partially opened to 12'....
manwithtools
Lebanon, TN
I like a bit taller door so I can back a loaded car hauler with my lifted Jeep on it. So I'll be using 10 x 10 doors.
DJF3
British Columbia, Canada
I would go with 10ft door, even if you don't need it. The next owner might. When we were looking for a house many years ago, there were so many garages that my 1 ton with a high rise canopy wouldn't fit in.
Stuart in MN
Minneapolis
I think I'd put the man door on the side. If it's on the front along with the overhead door, you'll remove most of the lateral stiffness of the structure. I'd make it at least 36" wide if not wider, so you can move lawnmowers, etc. through it without problems.
SouthernIllinois
I was going to go with 8' high doors.
My friends and the builder pleaded with me to go with 10'
I am glad I listened.
Better to have it and not need it than to wish you had it later.
racecougar
Missouri
If you have the height in the garage I'd go taller. At least frame it so you could go to a taller door if needed in the future. You know if you'll get the rv bug or take up some other hobby requiring a taller vehicle.
Parking a RV in a 24'x24' garage is likely going to be a little tight.
CraigStu
Blacksburg, Va
Pay attention to Stuart in MN. My SILL built his garage w/ two 8ft wide doors. Doing that made the walls between and on either side only 2ft wide. It worked out but he had to do things like run the door headers all the way to the side walls and attach them in specific ways. I don't remember the details but the side walls had to be oriented to that front wall a specific way also.
Triumphtriple
I went with 3 10' doors. I have 14' high ceilings. I don't regret getting tall doors. It wasn't needed though for my use. 9' would be more than enough.
