Hey guys.
I've got a dedicated central A/C and furnace setup in my garage all running off of a programmable thermostat. Does anyone know of a slick way to tie a door switch to my garage door and to the thermostat to tell it to turn of when that door is open? Either that or a built-in shocker that will zap my wife and kids when the leave the garage door wide open while I have the system turned on!
I've found some commercial applications but they are very expensive or just operate a series of dampers to shut-off the air flow.
I think it would need to be smart enough to actually tell the thermostat to turn the system off so that it can deal with any rapid open/close situations. For example, if I manually turn off my A/C for a moment and then back on, the thermostat always waits a few minutes before kicking back in to let the compressor adjust. I'd be happy to deal with that delay over having it just run when the door is open. Obviously the ideal solution is one that shuts off the system only after the door has been open for a few minutes.
Thanks!
Thanks!
