Hi everyone. I have a situation where the breaker panel is full and when my house was built the electrician was told to run two 220 outlets in my garage.
They ran one of my 220 outlets as a single breaker and set it up as a 120 socket because I guess he misunderstood why I was requesting at the time. he thought I was putting in a window unit and thought it would more than likely run only 110, but he was smart enough to place it on the 220 rated conductor. When I asked the builder about it he said that he talked to the electrician and that they said the wiring is there and if I need to swap to 220 simply change out the breaker and plug, connect the other hot on both ends. I double checked and it appears the wiring is a proper 220 rated wire and all 4 conductors are there, he just left a wire nut on one of the disconnected leg in the outlet and the panel so that leads me to the breaker question. Since all the panel openings are full there is no way to place the second breaker. I noticed one breaker slot already has a 1 inch thin Double 20 on it.
Is it possible to use another one of the 1 inch Double 20 breakers on this line or would I be better moving one of the house circuits, like the bedrooms, to the double 20 and then use both full size breakers for the 220 circuit? I am probably going to be running an air compressor on the line that is a 220v with 15 to 16 amp load rating (not sure if that is startup or continuous but I suspect it is 16 at start and then it drops some).
Also, the panel is a 200 amp panel, and I know that other circuits in the house will draw amps when in use, but most of the time when I am using the compressor I'll be in the garage and the only things that will run are going to be the AC or Heat, and everything else will mostly be on standby or not running. It's just me in the house so no wife and kids to worry about. Should I be worried about panel overload?
