I have done a search and I am more confused now than I was before I did the search. I am getting ready to build a 40x60 pole barn style building. The primary use will be 50% shop and 50% storage. I will eventually heat the entire area and cool the shop side. In doing a search some say put vapor barrier on outside of exterior framing before you put exterior metal panels up. And some say on top of the insulation. Couldn't I just use a 6-8 mil? To me, logic tells me to put it up between the exterior panels. That way any condensation will never touch the insulation. I found the 8x40 rolls of insulation local. I will put a 6-8 mil vapor barrier on the face of the insulation prior to putting up the wall panels. Undecided if I am going metal or OSB at this time. I'm just need to know which method is preferred. I live in southern Missouri.
