tcianci
It's about midnight and I finally got to replacing the rotted brake tubing on my kids car. I had a post a few months back about my first (unintentional) brake flush when I was replacing a rusted line at the rear of the car and started to bleed the brakes without the benefit of tightening all the fittings! So I dumped quite a bit of fluid on the driveway. Anyway... tonight I thought I had a plan to utilize the old ends of the original tubing (3/16, or for you commies, 4.7 mm) and splice in some fresh 3/16 tubing using a double flare tool and some double flare unions.
Theoretically, it works but it's not slick and I don't (well didn't) have the ability to make a real bubble flare. So I decided to poke around the interweb for a tool. I happened across a Utube video of how a guy used his double flare tool kinda backwards (die reversed) and used the double flare accessory to create a bubble. I tried it but was not impressed. Having nothing to lose I re-machined the double flare accessory on the lathe so that the internal chamfer was 45 degrees and gave it a try. Voila! I was banging out 45 degree bubble flares like it was a kids toy. At some point I need to invest in a new flare tool but using mine backwards (non-chamfered side of the die to press against) and the modified accessory, I was making bubbles with a nice 45 degree face and a good sharp shoulder for the nut to bear on. The proof will be when I bleed the sucker., we'll see if it leaks.
The first pic is a factory bubble, the next one is my home made bubble
