ncfireman1918
I’m in the process of finishing up wiring and interior walls in my shop. It’s a red iron 30x40 metal building (link in signature for poorly updated build thread). I have somewhere around 190 ft of conduit buried from the house, with pull string waiting on a cable pull. My FTP (shielded) direct burial CAT6 should be here tomorrow. Not sure when I’ll get around to pulling it. My plan is to provide a wired backbone to add a WiFi access point in the shop. I have a Google WiFi mesh network in the house right now, and have done wired points with Google WiFi before, so no worries on that part. Where I’m unsure is grounding the drain wire for the shielding on the CAT6. I am planning to punch down a keystone jack on both ends, and will use a patch cable to connect the end inside the house to a switch, the other will be a patch cable to the Google WiFi Point. I’ve never dealt with shielded cable outside a normal wiring closet/server room/patch panel config. Normally you either bond the drain wire to the chassis of the equipment rack, or bond to the shielded connector, and the ground is handled internal to the equipment (switch).
My CAT6 will be terminated in a low voltage box, on the other side of a wall stud from the electrical outlet that I’ll plug the access point into. I’m thinking that I should be good to just run a short jumper wire from the low voltage box around the stud into the electrical box, and bond it to the ground wire in the box. In theory that should take care of it, but I’m not sure if that is an acceptable way to ground the drain wire. BTW, went shielded because I didn’t plan as well as I should have, and ended up with conduit closer to the main power coming into my sub panel than I’d like. Had I been thinking, I would have brought network into a different point. Shouldn’t be a show stopper, just want to make sure my head is in the right place. Thanks!
Chris
Chris
