budl
Just saw and add for a good deal? on a double cut saw from HF. Says it cuts wood, plastic, metal etc. I'm not familiar with this tool. Do you use it like a skil saw? Anyone have experiences to share?
Bud
Bud
I have the Craftsman model. Looks identical. Those twin blades CONSTANTLY need to be kept lubricated or the blades start binding, putting a heck of a strain on the motor. Used it on aluminum, no problem. Used it on 1/4" plate and surprisingly, did pretty well. The bad thing is there is no way to really set up a guide to use as a straightedge, so pretty much have to freehand a long cut.
The twin blade turn in opposite directions, so the cutting action is similar to nibblers, but with tiny chips, as opposed to a long continuous ribbon chip. Be careful! Those chips are HOT! Very hot, and fly ALL OVER!
Holy ****, 1/4" plate?! From what I have seen, those saws are pretty tiny. How well did this work? Was it more shearing, or actually cutting?
Like I said, it did pretty darn well on the 1/4". The actual cut is very clean, almost like a cut with a cold saw.
