I think the Kett might be the only somewhat affordable “quality” shear, especially for 14 gauge.
Makita makes a strip shear, but I think it just maybe 16 gauge.
Sanwa is another manufacturer of industrial shears and nibblers from Japan, but their shear probably cost as much as the Trumpf and Draco shears.
Most of the other Euro shear producers are using Trumpf or Draco shear heads, and cost almost as much.
Some Dewalt nibblers and shears appear to use older Trumpf cutting heads, and are somewhat more affordable, especially in the USA, but O don’t believe this includes a strip shear.
Kett used to manufacture an inline shear closer to the style of the Trumpf/Draco shears, with a straight motor rather than a drill style motor.
I believe the 14 gauge version was the KL-240, found here.
https://www.mutualscrew.com/product/kett-tool-kl240-14-gauge-doublecut-shear-195111.cfm
It looks like this may gave been discontinued.
I’m not sure why, although the motor appears to have been a typical die grinder style motor, with a gear reduction to bring the speed down to that of the usual drill motors Kett typically uses.
It’s possible Kett was sourcing the motors from a Russian power tool manufacturer that is owned by a Russian aerospace parts manufacturer, so maybe there were supply issues( the Russian source is a guess based on similar motors and tools).
The inline version cost almost twice as much as the drill motor version, but it’s still less than half the price of a German shear.
As far as shear availability.
Trumpf has been selling shears in the US for decades, so while not the easiest things to find, I doubt they’ll disappear from the marketplace.
Draco is more obscure, but the shears seem to be showing up more thru roofing supply places and other specialty sources. This can always change, so Draco might be more of a gamble as far as future availability than Trumpf.
Fein also sells versions of both shears, and they’ve had distribution in PA from the 1960s or earlier.
Bone of the shear manufacturers, whether Kett, Trumpf, or Draco, use self nanufactured motors.
Trumpf in the past has used motors made by Fein, Milwaukee/AEG, Metabo, Bosch, and maybe others.
Draco used motors made by Fein, Milwaukee/AEG, Suhner, and maybe others.
Kett uses motors made by Black&Decker/Dewalt, Makita, and in the past Porter Cable, us that possible Russian made one.
If the motor or parts for the motor fail, parts should be available from sources other than the shear manufacturer including decent tool repair places.
Cutting blades for Kett shears seem to be readily available.
Trumpf shear blades should also be easy to find.
Draco blades might be harder.
Also, Draco makes double cut shears with blades for certain specific tasks like duct cutting, and serrated blades for seem cutting.
Another issue with the Trumpf and equivalent shears is the grease used in the motor housing.
Trumpf is very specific about this, and some older manuals lists possible alternative greases.
All were obscure, with the only one seemingly available other than the Trumpf grease in the US bring a Mobile grease that was also pretty obscure.
I presume there is a reason for the specific grease formulation, but don’t know why.
Trumpf also lists a seoarate grease for the cutting blades.
I believe Kett just specs a standardly available type of grease.
