FlameOut
I installed my 45000 BTU Mr Heater and it works great, but I was a little concerned about the venting.
I bought some 3" double wall vent from HD and installed it with no problems, but I noticed it gets VERY hot. I thought the reason for double wall is the outer pipe will stay cooler??
I'm worried about where it is passing through my wall. It is real close to fiberglass insulation and it's also passing trough the outer OSB and vinyl siding.
Right now I have the hole cut in the drywall and OSB to have a snug fit on the vent. Should I have the openings bigger so the vent doesn't touch? I am also assuming I should be sure no insulation is touching the vent?
Other than that, the heater seems to be working well. Took no time at all to bring over 900 sf up to 60 deg with outside temp at 45
