Downspout Heat
Ramper
Southern MN
Our downspouts are drain-tiled out to out pond (FAR FROM HOUSE). We just had gutters installed and I think the downspouts are freezing up. Can I run gutter heat tape in just the downspouts?
G_P
Central CT
Use the roof de icing cables. I dont think the heat tape for pipes is meant to have water flowing over it.
Krodad
Iowa
You can wrap downspouts with heat ribbon, but you'll still have an issue with the shallow buried tile to the pond.
Sent from my SCH-I535 using Tapatalk
Junkman
Northeastern CT
Check the downspouts for clogs of leaves. I noticed that I had icicles forming on the gutters today. That is when I realized that cleaning out the leaves too early in the fall wasn't a good idea. I usually clean them after Thanksgiving when I know that all the leaves that are going to fall, are on the ground. If your downspouts are clogged, then the only solution will be to wait till warmer weather, and then clean them. I would take them apart, because you don't want to move the clog further down stream in the pipe than it already is.
R
Ramper
Southern MN
The gutters were installed in NOV. We have no tall trees. I meant heat cable not tape.
Any suggestions as to were to buy heating cable? I assume that they will go on sale come spring
nehog
Jaffrey, NH
I'd fish the heater up the inside of the downspout, and just loop the bottom up so that water doesn't flow over it at the plug. Inside it is protected from wind cooling, and (IMHO) will work better.
R
Ramper
Southern MN
I think I will do the down spouts NOW and look for some low wattage cable and do the brain line in the spring
BlindViper
York, PA
No tall trees doesn't really mean much. I cleaned a restaurant flat roof in december for a ice issue. No trees with in 300 yds but one downspout was clogged with guess what? Leaves go figure.
