Hoping to get some experienced recommendations. I'm buying a used Clausing 20" 2277 with a 3ph 460v (only) motor. It already has a 460v VFD with it, apparently he was told that this VFD could run this machine off 220v 1ph which it didn't.
I have 220 1ph in my garage. I've researched and read all over about VFD's etc, step up transformers which seem to be way out of my price range. So what seems to be the most economical solution is to by a single speed 3ph motor and run a VFD.
Now the need for your experience, I'm seeing (1.5-2hp) 1750 rpm, (3/4hp) 1150 rpm, (3/4hp) 850 rpm motors as options. This will be used primarily to drill metal, maybe the occasional wood but 95% metal. Would I be better off with the slower RPM and less hp motor and then slow that down further with the VFD for cutting larger holes or on tougher metals? or higher hp faster rpm motor and just slow it down as slow as I need to with the VFD? I know when you slow it down with the VFD it cuts the hp available from what I understand.
Hope that made sense
Thanks for any input!
