So after a long search, I finally picked up a drill press. A little more info here.
I'm trying to figure out just which direction I want to go with the restoration/rebuild. I've read a lot, but would like to get some specific advice.
1. Cleaning up the column. I've started the WD-40/white scotchbrite pad work. I'm considering the 1/2" drill press polishing lathe as well as getting some buffing pads for my bench grinder. Tips? Also, once it's all cleaned up, I've seen others use anything from paste wax to boiled linseed oil (BLO) to protect the metal. Is there an agreed best way to attack this?
2. Pulleys. The pulley's on both the head and the motor are in pretty bad shape. I'd like to restore them, but I think they are too far gone. Are these universal pulleys, or are they specific to the drill press. I haven't removed these yet to investigate further.
3. Paint. Is there a preferred paint/process for cast iron? I've always used VHT high temp paint when painting engine blocks, and it has come out pretty good.
Hopefully having answers to these questions all in one place will help more than just me.
