Drain old compressor?
mike_s
I have a 1990s Craftsmen 25gal compressor that I haven't drained any possible moisture from in 10+ years.
It is rarely used. Maybe top off tires on lawn mower twice a month
I am worried if I try to drain it the likely corroded and might break off.
I dont seem to have moisture in lines casing issues . Leave it alone ?
JABgj
So. California
FWIW, I have a similar Craftsman compressor (that I rarely drain to be honest).
My biggest issue is broken connecting rod/piston assemblies.
johnre
Portland, OR
Once you do get it drained, disconnect one of the fittings and drop in a borescope to have a look at the rust situation. You may not want to pressurize the tank again, based on what you find inside.
