Frankengruvin
Mounted one Mr. Cool DIY 9k Wall Mounted Air Handler on an exterior wall, but with soffit the actual distance from daylight is about one inch shorter than the built in drain line. This makes the connection point for the drain line extension they send with the unit happen almost inside the wall cavity, and as it is just a corrugated plastic tube with a friction connection I do not trust it. Hence, I have decided that I need to go custom. I took the drain line off the second unit that I haven't installed yet to use as my experimental unit, and discovered that the actual plastic tube uses a rubber or silicon sleeve with a small metal clamp to secure to the little plastic (PVC?) nub that is built into the drain pan of the air handler itself. My thought process since last night was initially, to simply solvent weld (glue) an appropriately sized PVC pipe to this and then plumb a drain pipe down the inside of the wall cavity and exit at the bottom of the wall. Slope is not the issue here. My main question is can I even attach PVC to that plastic part of the air handler itself? I am not a plastics expert, just an avid DIYer. I am not sure if I can use standard PVC here with the standard adhesives, which I have, or at least can get easily, or if I need to use some other method of attaching my own drain line to the Mr. Cool unit, such as a flexible tube of some sort. I measured the outlet pipe on the unit with calipers, although it was a weird angle, and it appears to have an inside diameter of 1/2" and an outside diameter of 5/8". The color of the plastic is gray, if that matters. By the way, in removing the insulating tube from the drain line I damaged the Mr. Cool plastic tube to the point that I wouldn't trust the connection if I put it back on. So I'm kind of committed to a DIY solution anyway at this point.
