draining oil from a Model M Hein Warner jack
1930artdeco
Lynden, Wa
Ok. I just bought a 2 ton Model M Hein Warner long jack. It holds weight as he lifted his F350 front end and it held for a few hours. I didn't see any leaks on the ground-good sign. However, it would seep out of one on the screws on top a little, not a lot but you could watch it. I also heard-what I thought-was air moving around in the system and bubbles. So I would like to drain out the old oil and refill and bleed it to see if lift any easier. To that end:
A) where is the drain plug?
B) where do fill it and bleed it from?
Thanks,
Mike
1930artdeco
Lynden, Wa
Here she is. Somehow the rear of the jack got bent outwards😱. I mean that is some damn good steel there. She is probably from the 80’s as she has a caution sticker on the handle.
Hiball
Missery
I feel like it’s been awhile since I’ve tackled HW M, but if memory serves there should be a angled plug/screwdriver head that covers the fill port on top side. All your vertical plugs are valve components and not for filling or draining. I would try and tighten the plug that’s leaking. It will be a bear/messy to drain without removing the hydraulic unit. It’s possible that it’s a little low on oil and that’s what your hearing. Unfortunately HW makes it difficult to know what the current oil level is, it’s a sealed unit so you fill it up with X amount of ounces and your good to go. A picture of the top of the hydraulic unit should help identify the fill hole.
1930artdeco
Lynden, Wa
Thanks Hiball,
I will post a pic of the top of the hydro unit. I think I know which one you are referring to though.
Mike
1930artdeco
Lynden, Wa
Here is the top of the hydro unit. I added a little oil and it seemed to help out a bit.
