Drawer slide lube
Makman
Middle TN
Hi all. Im a newbie here. I have a 1974 kra396u taco wagon im refubishing. Can anyone tell me what's best for lubricating the drawer slides?
Thanks
Matt018
I always keep an oil can around the shop, either with auto trans fluid, or motor oil. A squirt or two on each slide works alright.
biscuit141
Indiana
I used DuPont aerosol dry wax. So far so good. Grease traps a lot of dirt over time so that's why wax is recommended.
2oolhound
BC Canada
Do you use the same lube for ball bearing slides as you would for friction slides? Anyone tried graphite powder?
Steevo
43.49600, -112.04300
I lubed my friction slides on my brand new Snap-On cab and box with a light moly grease and thirty-three years later had to clean the slides and do it again.
Sheesh!
High maintenance!
M
Makman
Middle TN
Thanks for the info guys. I'll do some experimenting to see what works best. Also.. 2 of my slides have a slight dog leg in them making the drawer kinda tight. Any suggs on straightening?
Thanks
2oolhound
BC Canada
I have flat faced jaws on my 6" vice and clamped my bent sliders in them, than whacked the bent area with a chisel and a flat punch that fit (right on the bend). The chisel left a few marks but over all the slider is straight and the drawer works great now.
CaseyJoes.
Strasburg, PA & Eastern Shore Maryland
Use paraffin wax (aka canning wax). This is what these boxes had on them originally. I tried PTFE dry lubes and it did not work (at least nowhere near as well as the paraffin). Grease or oil will just attract dirt to the slides and eventually make them gritty and abrasive. If you put the paraffin on the slides and their grooves the drawer will glide smoothly and easily even when heavily loaded! It will last a long time and not attract dirt. You can get the small box of paraffin wax at walmart in the canning section for just a couple bucks and it will have enough wax for at least 50 boxes worth. Its handy for lots of other things too like wooden slides etc.
M
Makman
Middle TN
I put them in the vice with a narrow piece of 1/4" plate on each side. Fixed em right up. Tried the dry lube with no success. Forgot to mention they are friction slides. Settled on the synthetic grease that i use on my skidloader. Seems to work ok. If i have trouble i'll do the wax. Thanks again to all. This place is awesome!
