I have had a Dremel XPS in the shop for 5 years now, it doesnt get much use as I have lots of air tools, but there are times when the weight and maneuverability of the dremel make it handy.
Over the past year it died slowly, first charring the stator a bit and then today total meltdown.
I have never been happy with the torque (it bogged down easy) or the duty cycle - it seemed it needed to be cooled off every 3 minutes. I used compressed air to keep it cool on breaks, but still it eventually died.
I have a fair amount of dremel bits so I would like to replace this with something that uses the same collet size, but something with a much better duty cycle and torque. I am thinking in the 5-8 amp range with a good internal cooler fan if the XPS was something like 2.2 amps.
What alternatives and recommendations do you have for something that is compact, sturdy, powerful and used dremel-style bits. And available in Canada - 110/120v.
Thanks!
Thanks!
