Dremel Brushes
AceofSpad3s
Wire brushes and wheels like to shed, given how small the dremel ones are it's probably just comes with the territory.
Try Electrolysis if you really want to some time, though if you are just doing really small spots or light surface rust it might be a bit overkill.
Stadger
I hate the rotary brushes of any manufacturer. Picking those little wires out of your clothes is miserable. Now I just buy the cheapest and pitch 'em at the first sign of shedding. Slowing the tool down and using minimal pressure seems to help.
Dave455
Sussex, England
Try ordering some from MSC - I’ve used them and they are better than the Dremel ones.
Have you got any other tool you could use. Even the cheapest angle grinder with a half decent wire brush would be a big step up!
W
WarrenJ
East Coast or Right side of country
I"ll check out MSC. Agree I hate picking small wires from my clothes. Starting to wear a cover over my shirt.
Thanks for all the suggestions. I bought some Evapo Rust, need to get it started on some pieces.
Tools85
East Coast
All my wire brushes do this eventually. I have been getting the harbor freight ones recently. They dont last as long and start throwing first but the overall cost durability seems to be better.
frank001
Southern California
I've had the same problem with rotary brushes on a Dremel. I found a solution was to put a bead of hot melt glue around where the wires attach. Makes a big difference.
Wamsutta
Amarillo, Texas
At this point I'm assuming the OP doesn't have variable speed. That's pretty much a necessity with a lot of the Dremel implements unless you're using rotary files or router bits.
RonnieC
Orlando, FL
This is timely- I was running a brass wheel in my dremel yesterday while wearing a short sleeved shirt. My left forearm looked like a pincushion!
Thanks for the hot glue suggestion!
Parrothead
Earth
Thank you! I use my Dremel regularly, and am so annoyed picking wire shards out of my clothes and occasionally skin.
Brand doesn’t seem to factor either.
jg4660
Western NY
Try a heavier wire wheel in a cordless drill. Much better unless your working on very small and delicate items.
JG
Widget supply delivered today, quite fast from Oregon. Took a package from across the bay longer to get here. Will pull it out if quarantine tomorrow and check the quality.
