Dressing up a metal building?
Elyat
Hill over house
I’m contemplating a shop/garage build in the 30’ x 40’ range. I’m thinking metal build and want it to look a little nicer than your average metal building. I’m thinking maybe either lap or vertical siding for a start. Anyone ever seen this done or have suggestions that might look good? For what it’s worth I’m in coastal N.C. so hurricane awareness.
Thanks
nadogail
Coronado, CA
A good coat of paint will make any metal building look better, you might add a contrasting color trim.
kj_mustang
Harrisonburg, VA
Contrasting colored trim and roof with wainscotting in metal or stone veneer. Look on some of the large pole building company websites at some of their build pictures and you can get some good ideas.
readhead
Durango, Co.
Consider some other panel profiles. There are a lot to mix and match. We do this often on commercial projects. Wood siding can be done but will require some more planning with either more girts or adding wood framing to attach the wood siding.
What type of metal building are you looking at? Some will be easier to add wood siding than others.
NUTTSGT
Northern Central Ohio
These guys do some nice work;
I was going to suggest checking out some of Kyle's videos with RR Buildings. He does some nice work. Probably not cheap but alot of attention to detail.
kj_mustang
Harrisonburg, VA
All it takes is money and imagination.
finn
The UP, God's country
My garage is stick construction with metal siding, but I went with 3 courses of split faced block, a few feet of contrasting wainscoting, then the metal siding.
I also did a stepped roof, which really makes it look less commercial. 8’ studs above the block for 30’, and 10’ studs for the remaining 24’.
Overall dimensions are 32’x54’.
jack stand
Lakes Region Maine
Go and look at Morton's and Everlast's website for some ideas.
Like said above, add money and imagination ie; shutters, generous overhangs, accent color for corners soffit & fascia, wainscoting panels are effective in visually reducing the height and is virtually no extra expense.
