Drill a crack?
robertwhite
I have a small (basically hairline) crack that came from the ramp not being separated from the floor with a control joint by the concrete guy. Once I saw it, I cut joints in the entire slab.
When I washed the floor the other day, I noticed that the tail of the hairline goes about 4 inches past where I cut the joint. The ONLY way I saw it was because the water showed it, thats how fine of a crack it is at this point.
So, can I take say a 1/8" drill bit and drill a small hole at the very end of where the water shows the crack to be? I am thinking that it would act as a control joint of sorts for that crack, no?
R
robertwhite
That crack is likely to be all the way through (top to bottom). Better bet is to fill with a slab bonding sealant.
There is absolutely no way to fill the crack unless I physically made a cut in the floor. As I said, the ONLY way I even knew it was there is because water creeped into it, thus highlighting it. I can't even feel it with my fingernail.
Even the actual hairline from which this sprouted is BARELY visible for at least 2 ft before it (4ft total length), and the starting point is not open at all, it is just a tiny bit more than a hairline.
I understand your logic, but making a cut and then filling it would be like putting the cart before the horse.
Cabby89
Leave it alone. It doesnt sound like a terrible problem and one that is not seen.
If it gets worse taking Legacy's advice is best. You will just have to get a crack chaser to make a V cut thru it.
R
robertwhite
Crack chaser? Never heard of such a thing. Link?
And no, it is not currently a problem, but it is in the section where my lift will go. That is why I would like to ensure that it doesn't get worse.
ConCretin
Central Maine
Robert, a crack chaser is just a diamond blade for a grinder that cuts a 'V' groove at the surface of a crack to create a void for sealant.
I agree with Cabbby89, I'd probably just leave it alone. It isn't structural and the repair will look worse than the crack does.
I get the logic of drilling a hole to stop the crack but my sense is that it wouldn't be worth the effort.
R
robertwhite
Oh, OK. I got's me one of them thar' crak chasers. (4" and a 7 1/4" that I cut my control joints with it)
Sounds good. I guess I will just keep an eye on it.
Thanks guys.
