alex71
This post contains drill bits and accessories, brace bits, yankee drill points.
Prices do not include shipping. If you think I'm out of line on a price, please let me know. I base my pricing on various sources on the internet, such as MSC for tooling, Amazon, eBay, etc., but sometimes I just have to guess.
PLEASE do not send PMs. Email only. Please!
All items made in USA unless noted. All items NOS unless noted. Most are in new condition. Some have a little grime, but nothing that can't be cleaned up. Look at the pics, and ask questions. Numbers in (parentheses) are my quantity on hand, if more than one.
Please do not PM me! Send me email at alex at asmc dot net
HSS Drills. COO is either USA, Italy or Yugoslavia (very few are Yugo). Drills are very high quality, I drilled some test holes and they work very well.
Straight Shank:
23/64 (6) $4
27/64 (18) $5
29/64 (7) $6
31/64 (3) $6
15/32 (26) $6
Reduced 1/4” Shank
11/32 (20) $3
15/32 (46) $6
Countersinks, straight shank, HSS
Stanley Carded 5/8” (3) $4
Mayhew Rose (9) $5
Deuse Rose (~12) $5
General #55 circle cutter, 1.72-8”. $15
Stanley Lock-Set bits. Spot of rust on each one. 1-3/4” or 2” $8
Stanley Plug cutters
7 pc set (2) $30
3/8” hole, 1/2” hole, 5/8” hole, #6 screw, #8 screw, #10 screw, #12 screw
5 pc set (2) $20
Open stock
5/8 hole (2) $5
#6 screw (1) $5
#8 screw (1) $5
Sorry, forgot to take a pic, but they look just like this:
http://westsidedelivers.com/images/products/STAPRO/04723.jpg[img]
Stanley adjustable bit guage (5) $5
[url=http://asmc.net/pics/d/12624-1/IMG_3463.JPG][img]http://asmc.net/pics/d/12626-2/IMG_3463.JPG[/url]
Stanley holesaw mandrel. A bit unusual (look a the pics) but I did install it on a holesaw I have and it seems to work, although I did not try to make any holes. (3) $2
Wood boring bits, straight shank (either round or with flats ground into shank, for power drills)
Irwin Speedbor Spade bits
11/16x6.5” long (7) $2
1-1/8x6.5” long (13) $2
1-3/8x6.5” long (3) $3
7/8x16.5” long (7) $7
Stanley 7/8” Powerbore bit (2) $8
Irwin 1/4x7.5” dual auger (14) $5
Irwin 1/2x18” installer bit (hole drilled near head) $10
Irwin 3/8x18” installer bit (hole drilled near head) $7
Irwin Brace Shank (for 2-jaw chuck bit braces) and adapter shank (both brace shank and flats ground for electric drills—brace shank can be cut off) wood boring bits. Should be able to cut the brace shank off any of these to use in a modern drill. Note: I had a very difficult time determining pricing for these, because items like these are simply not available in new condition. Prices are based on an amalgam of completed ebay listings for used bits like these and modern versions sold on Amazon.
Expansive wood boring bits
#1 expansive bit, 5/8 to 1-3/4” hole, brace shank (17) $15
#21 Microdial expansive bit, 5/8 to 1-3/4” hole, brace shank (6) $16
#22 Microdial expansive bit, 7/8 to 3” hole, brace shank (30) $22
Irwin wood augers and other wood boring bits. All sized in sixteenths. For example, 18 is 18/16, or 1-1/8”
Short bits, 9” long. $10 each
13/16, #62T (top in pic), brace shank (8)
13/16, #100 (bottom in pic), brace shank (3)
16/16, #62T, brace shank (8)
11/16, #62t, brace shank (5)
12/16, #62t, brace shank (3)
14/16, #62t, brace shank (5)
15/16, #62t, brace shank (4)
18/16, #62t, brace shank (3)
20/16, #62t, brace shank (2)
22/16, #62t, brace shank (3)
24/16, #62t, brace shank (bottom in pic) (6)
24/16 Acrabore, brace shank (top in pic) (1)
Bell Hangers drills, 18” long, $15 each
5/16x18” Bell Hangers drills, brace shank (3)
10/16x18 Bell Hangers drills, brace shank (4)
Utility Pole/Car bits, 18.5” long $15 each
6/16, adapter shank (12)
8/16, adapter shank (6)
10/16, adapter shank (24)
11/16, adapter shank (10)
11/16x18” long electricians bit, brace shank, in tube. (2) $15
Rose countersinks, Brace Shank.
Stanley 3/4” SOLD
Mayhew 5/8” (14) $3
Mayhew 1/2” (12) $3
Mayhew 3/4” (18) $3
Mayhew Factory assortment, 1 dozen of the above sizes in box. (7) $25
Stanley drill points/yankee drill points. For some reason these are going for crazy prices on ebay. I have priced them well below the going rate, which is pretty astronomical.
Stanley Yankee drill point 3pc set (fit spiral screwdrivers) (4) $20
Stanley 02-923 (923-10IN) bit brace (2) $50
Stanley bit brace replacement jaws (not for the brace above. See pic)
Type I (2) $5
Type J (6) $5
Look for much more woodworking stuff in THIS post.
Huot Drill indexes
#15 (1/16 to 1/2 x 32nds) (3) $8
#715 (same as above, not pictured) $8
#29 (1/16 to 1/2 by 64ths) $10
Straight Shank:
23/64 (6) $4
27/64 (18) $5
29/64 (7) $6
31/64 (3) $6
15/32 (26) $6
Reduced 1/4” Shank
11/32 (20) $3
15/32 (46) $6
Mayhew Rose (9) $5
Deuse Rose (~12) $5
7 pc set (2) $30
5 pc set (2) $20
Open stock
5/8 hole (2) $5
#6 screw (1) $5
#8 screw (1) $5
Stanley 3/4” SOLD
Mayhew 5/8” (14) $3
Mayhew 1/2” (12) $3
Mayhew 3/4” (18) $3
Type I (2) $5
Type J (6) $5
Huot Drill indexes
