Drill Bits for drilling Truck Frame-Mounting a Trailer Hitch
Model A Fan
NW Washington
I'm looking for a recommendation on bits for installing my trailer hitch on my truck frame. I need ones that will drill through frame steel, so a recommendation on which type to use would be appreciated. All I need are 1/4", 3/8", and 1/2" for this project.
seber
Deep East Tx.
Hitches should mount to pre-existing holes. As far as the steel, it is not anything special. A bit harder than mild steel but still OK with standard drill bits.
PCustoms
VT
What do you have?
Generally No reason to get some exotic bit for aa few holes, assuming you have something decent already
Wrench97
Southeastern Pa
High speed steel(HSS) or Mechanics bits(shorter) Decent brand like Hanson, Latrobe etc. Start small and work you way up in size.
Over the years I've drilled hundreds of holes in semi truck and trailer frames using HSS bits from many different brands they all will need to sharpened in a grinder wheel at some point.
Model A Fan
NW Washington
Its a 1996 F-150, so nothing exotic. I have a cobalt drill bit set I believe, so I'll just do that one slow and with cutting oil.
What do you have?
A regular cobalt drill bit set should do it then, which is what I have (somewhere 😅).
What truck is it that you have to drill holes? Must be something uncommon or a generic multi-application hitch?
1996 F-150. The truck never had holes for a hitch, so I bought a Draw-Tite hitch for it (it is specifically designed for the truck, but it came as a bumper mount from the factory, and I am not going to use that to tow anything of consequence). I'd like to know my trailer won't break off the bumper going down the road.
OccupantRJ
Eastern North Carolina
Drilling vertically can be tough if it is needed. I like to use an old school 1/2” drill with a keyed chuck and 1/2 pipe size screw in side handle At least a foot long. If you have a friend to help, you can use a 2x4 as a lever by placing a 4x4 block on the ground as a fulcrum, sit the drill on top, and run the drill while the friend applies pressure judiciously. He pushes down on the lever while you concentrate on the drill. In construction work this is called an “old man”.
sparky 1971
Central Iowa
lt's been many, many, moons ago, but when I was in high school my weekend job was at U-Haul repairing trailers, washing trucks, and installing hitches. I would clamp the hitch to the frame, then, using whatever sized bit I needed for the bolts, start it just enough to mark the center. Then go back and drill it out with a 1/4" bit and finally, drill it out to full size which I believe was 1/2". Some frames were tougher than others, and sometimes I was out of sharp bits; in those cases, I would put a jack under the drill and let it do the work. There was nothing special about the bits, and I don't know if the fancy bits we have today were even a thing back then. All I know is that we had the cheapest bits available. One thing to watch for is the hot little metal shards falling down into the crook of the elbow between the bicep and forearm. Either be tough or wear long sleeves. Some hitches will match up to existing holes, some hitches will have a couple of hole match up to existing and the rest need drilled out. It wasn't very often that I had to drill all of the holes.
Milton Shaw
I wonder if you do this a lot, what about a cheap short table top drill press with the head turned upside down. Jack up the frame (not suspension) and position the upside down drill press as needed for vertical holes. Might need to add some bracing to the base to keep it steady. Or if you do it a lot then a core drill set up with the head again turned upside down. It will give you more torque and better control. Even a mag drill with removable head could be mounted upside down to get the work done, just get a piece of steel to mount the drill to and place on the floor for stability. Just a couple of ideas to consider depending on how many holes and frame you run into.
PCustoms
VT
Why not just use the mag drill as intended?
Milton Shaw
Normally on pickup truck and car frames, there is nothing to attach it to that is flat or big enough to hold even just the weight of the mag drill. At least on the two or three frames I have tried to put on my own cars. Now on bigger truck frames there might be enough space unoccupied to get a drill to mount too. I think I remember that a lot of truck frames are engineered not to have any more holes drilled as they generate stress cracking.
RoninB4
Under My House
-Sharp, decent quality, HSS drill bits are important but an often overlooked factor is drilling speed (RPM). Running too fast may seem like it gets the job done quicker but that's not what really happens. Every cutting tool has a speed range it can operate in, beyond that the cutting edge is burning and getting dull. Signs of the cutter running too fast are discolored chips (yellow/blue) and/or increasing pressure needed for cutting. Cutting oil helps allow some of the heat to go into the chip instead of the cutter.
When I can't select a given speed per the formula I use a visual aid to help. When the "flutes" of the drill just start to disappear that's the upper speed limit for what you're doing. Going faster than that will just burn/dull the cutting edge and a re-sharpen is required, applying more pressure can result in a shattered drill. This visual rule-of-thumb is for mild steel, you still need to watch the color of the chips coming out to know what is happening at the cutting edge. For other materials, particularly SS, the speed must be much lower. Cutting SS too fast will burn/dull the cutting edge and can also work harden the material you're cutting, making the task even more difficult.
You don't need special drills, you just need sharp ones from HSS (avoid cheap carbon steel) and follow the rules of cutting speeds.
mike93lx
Richmond, VA
I'm surprised it doesn't have holes. TIL
cherrybomb
Near Madison Wi.
Speeds and feeds are very important.Dont be afraid of pressure,a nice ,non blue chip means your bit is good and your cutting oil is keeping the bit cool and lubricated
Model A Fan
NW Washington
Thank you all for the advice and information. I have a few sets of Harbor Freight bits acquired over the years and then a set of cobalt bits from Grizzly. I don't use this truck on a daily basis, so if those don't work, I'll spend a few more bucks for Bosch or something that will be probably overkill, but usable in the future for similar projects.
Its been since last summer that I bought the hitch, and now that the weather is such I don't mind laying on the ground outside, I figured I'd tackle a (functional) project.
Old Man Roger
Palm Coast Florida
Here is another method.
Beat me to it. I’ve drilled hundreds of frames for trailer hitches when I ran the muffler shop. Only advice I would add to that video, use a longer board for more leverage.
This way you don’t have to use multiple size bits for each hole, just grab the half inch bit and drill.
Most times we didn’t need any straps, we would just put the board over the rear axle.
2 people makes it even easier.
Sno-Pro
https://triplesproducts.com/product...It works good with a corded or battery drill.
