chad s said:
1200 rpm is actualy too fast for cutting through steel.....
I highly reccomend a drill set from Chicago Latrobe, Precision Twist, or Champion Cutting Tools.
Spot on, Chad.
1200 RPM in steel would be a pretty small drill. For a larger drill - say 1/2", your RPM will be around 500RPM
on a machine and probably around 300 or less by hand with a small pilot hole.
Remember - if you are making noise, you are making heat and you are cooking your drill. If you are making chips, you are making a hole. When you finish driling, the drill (bit) should NOT be hot to the touch. If it is, you were either spinning to fast or not applying adequate pressure. Adjust speed and feed until you obtain long, curly or stringy chips and your drill will only be warm when you finish - the chips will carry almost all of the heat. Most of the time you will be suprised how slowly you will be spinning the drill and your drills will last for many, many years requiring only minor touch-up every once in a while. Use a Drill Doctor if you are not well versed in sharpening.
Make good chips - the hole is the by-product.
Precision Twist drills are your best bet I think.
Scott
