Drill Chuck key
thunders
I have a 1/2 capacity drill Chuck on a old drill press and need a Chuck key, the only marking on the Chuck are H2862 ! Any ideas on what key I need ?
Sent from my XT1254 using Tapatalk
fatfillup
Finksburg, Md
First you would want to know the size of the hole and number teeth per inch in the chuck. I would think that would help and you can certainly measure both
nh_yota
Seacoast New Hampshire
I think they are fairly standard for the most part and vary based on the size of the chuck (1/2" vs. 3/8") so if I were you I would go to the local hardware store and buy a 1/2" chuck key to see if it fits.
T
thunders
Thanks for all your help, I am going to measure the hole size and count the teeth and see what happens.
fatfillup
Finksburg, Md
Not even close to standard. Not that I am so smart but I likely have 50 + keys I have gotten out of tool boxes and box lots and there are a lot of variations. Not that some don't kinda work and cross over but to get one that fits right, you need to be exact.
Now there is likely 4 or 5 main ones though.
Tinner
N.E. Wisconsin
The easy way to do this would be to pull the chuck off and take it to an industrial supply house. They should be able to help you.
T
thunders
It is a Jet model 13 R . I think I will take the Chuck off and go to a tool shop.b635d20c2ca45fdf78f715631fcdac30.jpg
