ChristopherLutz
I have " a ton " of old bits that I can't bring myself to toss....anyone have experience with the Drill Dr.? thumbs up/down?
Opinions appreciated.
I've got the original 750 and I'm happy with it. It's not the caliber of a Darex, but for home use it's good.
I've got the original 750 and a Darex too. I still need to sell the Darex, it doesn't get used any more. The DD is made by Darex anyway. Once you get past the fact that it's plastic, it is a fantastic tool.
If you watch the videos, get acquainted with how to align the bit in the chuck. That, and the smooth motion you need to do the grinding is the hardest part. If a bit is really bad, you may need to do some heavy grinding, and then realign the bit in the chuck for a finish polishing, because as you grind the cutting edge back, the angles all change on you, and there's only so much you can grind before you need to readjust.
Just out of curiosity, what Darex model do you have?
I tried sharpening bits with a grinding stone but I can't get it right. It's a skill I need to put more time into learning.
Do you have the model that has the spade bit attachment or are you able to sharpen spade bits on the regular Drill D model?I have been able to sharpen wood paddle/spade bits also.
am I the only one that sharpens "manually" with a typical bench grinder?
mine is a piece of ****, there has to be a better way to sharpen drill bit
I had two. Used them to sharpen up my few bits that needed it. Shelved them both.
Bits don't stay sharp and I can buy cheapie drill sets at Harbor Freights bits to replace them with less hassle and lasts longer.
