I've got an older 24V nicad drill. It's a pretty cheap **** GMC brand, but I've kept it because it's got a 13mm chuck (my newer drills are only 3/8 or 10mm).
Yesterday however it up an died on me. Well not totally dead, it runs as long as you don't try to go full speed. When you depress the trigger it speeds up as normal, until the trigger is fully depressed and then it just loses all power and cuts out.
I'm guessing it's the trigger unit. Just wondering if anyone else has had a similar experience with a failure like this. I always thought they would go out completely when they failed, but this is like a half failure. The variable speed works ok but full speed is totally dead.
Just guessing here, but I think maybe the trigger has contacts that bridge out the variable speed circuitry to provide full power when the trigger is fully depressed, and those contacts must have fired or something. The only thing that seems weird about that is that I would have expected the thing to still work in variable speed mode (without full power) with the trigger fully depressed, but it actually cuts out the power completely. Weird?
Very annoying as I just rebuilt the battery pack on this one and was hoping to at least get a bit more use out of it. Oh well, that's 20 nicad subc's I can probably find a use for somewhere down the line.
