Drill Press Alternative
Zewnten
I’m working out of a very small shop for the foreseeable future. A floor drill press takes up too much floor space and a bench model takes up the same with a stand. Any drill presses that have low enough RPMs to be useful are quite large as expected being heavier duty than a hobby machine.
A mag drill would be more in line with my storage but they have no clearance from the base to the bit. Makes it less useful unless you’re drilling on structural steel and thick at that for the magnetic to grab.
Anything out there that is the equivalent to a drill press as a track saw is to a table saw?
humpty
Minneapolis, MN
They make drill guides in various price ranges. I have the Rockler one, it is decent. It will not compete with a drill press or a mag drill but will help you drill consistent holes.
  • Like
Reactions: T45
Packard V8
Spokane, WA
Just how large in diameter are the holes you'll be drilling in steel which will require a low RPM/slow speed DP?
jack vines
Nutria
Eastern Sierra
Gramma left me an antique PortAlign but I wouldn't use it in a shop.
I have one of those, and I use it frequently when I have to "take the 'drill press' to the work" rather than the other way around. That's been almost entirely for wood though.
GeoBruin
A mag drill is a really nice thing to have, and some of the stands I've seen put together for them would make them workable for some "drill press" tasks, but a drill press is a pretty fundamental tool for a lot of things. I think I would sacrifice just about anything else in my shop to keep a drill press handy.
Do you have any storage cabinets a drill press could live on? My drill press (a 15 inch rockwell) came to me mounted to a bench with a chopped column. It has a big ole' baldor dc motor on it with a variable speed drive and works a trick drilling steel. Your z axis work envelope might suffer with a Benchtop press but you don't need an Arboga to drill steel.
Regarding Portalign
I was given one recently, last used one almost 50 years ago. Definitely only when REALLY needed in the field. Trying to recall which drill I can easily leave with it
Z
Zewnten
jack vines
1/2 inch holes in up to 1/2 inch plate maybe some thinner AR occasionally. I don’t need great precision as much as good down pressure and slow speed. I found something called a Cole drill but it’s hand powered and slow. All the drill presses I find would need a third pulley added to get below 500RPMs, most I’ve found only go down to 600-700.
I was thinking of trying to find a heavy duty/well built contraption that adapts a heavy duty corded drill to a drill press.
larry_g
oregon
Bessy
Ontario, Canada
A 12" variable speed bench model drill press was about one of the first non-handheld power tools that I purchased for my shop. I don't use it a ton, but when I need it, I need it. I'd certainly make the room for one if I had to do it over. Those portable units like the rockler one linked above are good too, I have one made by milescraft (sp?).
Jswain
Calgary, AB
Do yourself a favor and get a mag drill. If you really want to make it pleasant get annular cutters for the bigger size holes(1/2" might be the small end for them)
Screw machine length drill bits & you can always put it on top of a piece thick steel/thick tube to gain height, or make a stand.
Unless it's a 1/2" hole through 1/2" plate once a year...
nadogail
Coronado, CA
At my last employer we had a need for a Lightweight Light Duty Vertical Boring Machine, I saved the job and the budget with a small Harbor Freight drill press and an 11" hardware store pulley for the spindle. We now had a Ultra Light and Ultra Cheap solution to the problem.
The bigger pulley gave us the slow speed we needed.
Z
Zewnten
Have you considered one of the styles linked above? I have one and it will do the job when necessary. They seem to show up often.
lg
no neat sig lineBummer wishes I lived closer that looks like a nice setup
Bummer. Wished I lived closer that looks like a nice one. Only found one around me and it’s all chewed up on the base plate
exmaxima1
Midwest
I've used one like that a number of times to drill/tap large holes in thick aluminum plate. The plate was too big for my drill press with tapping head, but the Portalign worked fine with a heavy duty hand drill.
Packard V8
Spokane, WA
Don't let the perfect be the enemy of the plenty good enough.
Also, you're not marrying a benchtop DP. Buy the best one available today and if a better option comes along later, the first will usually sell in a weekend.
For fifty years in the garage shop I've been using a 1940s Delta 14" and in the basement shop a Delta 10" to drill 1/2" holes in mild steel plate, among other things.
Clamp the workpiece securely, begin with a 1/4" pilot hole and finish with a 1/2".
BTW, if a slow speed is absolutely required, such as a large hole saw, adding a center pulley is not rocket science. Several here have done it and shared their projects.
jack vines
whateg01
doo dah, kansas, usa
I have an old bench top craftsman/atlas. I put a 6 pole motor on it and it will easily drill 1/2 Holes in steel. If you can make the top of the bench a flip top, it can be put out of the way when not in use.
Disclaimer: I still put big drills in the 20" W-T given the choice.
