Drill press base
Sumboodie
AK
Got this unit at DRMO auction for about $100. No idea what they did but it works fine.
Missing the pulley cover, but I usually leave those open anyhow.
Debating if I should do a new base out of some angle iron or? Anyhow have a measurement in length?
It's about 13" wide
Have some 2.5" locking casters to use too, will make it practical to tuck away unless being used.
no704
I was going to say find a scrap press and replace the base with that? I suppose you could lag it into the concrete?
Sumboodie
AK
Would be really hard to move around if it's bolted to the floor!
dutchgray
Dorset. England.
Bases usually get broken whilst the drill is being moved, drill gets dropped or a hard bump and it cracks, even happens if you transport the machine upright and go over a bad bump in the road without the drill being strapped hard down.
whateg01
doo dah, kansas, usa
What model is it? Might be able to find one with a bad motor or quill. Or a piece of plate, as suggested. I sometimes fill a tire with concrete and use that as a base. It doesn't vibrate and walk around, though a still press shouldn't walk anyway.
Sumboodie
AK
Was from the Army, so who knows with those guys. Probably tried using it as a hammer to open a can of beans 🤣🤣
OccupantRJ
Eastern North Carolina
When making a metal dolly or mobile base I have stopped drilling for bolts years ago and now tack weld the casters onto the frame. It is much quicker, the bolts are out of the way, and if I ever need to change a caster, a grinder with a cut off blade will make short work of it. It also saves hardware as well as drilling, or drilling and tapping. I have replaced hundreds of casters in my factory days, but never one in my home shop due to failure. They don’t roll enough for that. If you get a flat spot on a caster you can just change the wheel instead of the entire caster frame. For hardware storage cabinets I have gone to steel casters to prevent flat spotting due to weight.
Sumboodie
AK
I've got a 20" Cman drill press. I can go out and measure the size of the base if you want.
Sure, would help give me an idea on what I need to make.
The piece that was left is very light and thin. Just some cast material that's 1/4" at most.
Sumboodie
AK
Looks like a relaxing afternoon of welding to me.
Some 1/4-3/8" plate, a few pieces of angle or channel, a little cutting, welding, drilling and tapping.
It'll never break again.
Yeah, just have alot if other stuff to do too.
Been putting in 16+ hr days working on stuff.
Up now, it's 0130. Wicked leg cramps, probably didn't drink enough. Haven't ate much in the last 2 weeks. Had to put a new hole in my belt.
OccupantRJ
When or if you make a base you can leave the top plate short of the size of the frame by 1/4” all around, then when welded it is easier to grind a radiused upper corner to look more unitized and less harsh. I have my 20” Walker Turner drill press sitting on top of the smaller Harbor Freight dolly which is how I moved it into position. I like the portability so I left it under the base. My base is very close to the size of the small HF dolly, but it is a rather large unit also.
NUTTSGT
Northern Central Ohio
Gonna have to give me till Friday, I'm at work the next 48 hours.
Shoot me a PM if I forget about it. You can also check out the Cman I repaired in my Garage Refurb thread. Should be about 8-10 pages from the end...holes in the welding table are 6" apart if you check it out.
david3921
Wyoming, Michigan
$100 would be worth it just to save time, but then I saw the $300 shipping.
$100 to a L48 address, so still not cheap.
Not that heavy either. That broken chuck which is about 1/4 of the base, is maybe 5lbs. Surprisingly light.
Yeah, I thought that shipping cost was nuts too. A lot if the bases show high shipping costs on ebay.
kbuhagiar
Escondido, CA
Shipping costs are sometimes set indiscriminately on Ebay. For example, if the seller uses another Ebay auction as a template (very common and actually encouraged by Ebay) but doesn't adjust the shipping details (i.e. dimensions & weight) the information from the old ad will just transfer to the new ad.
Hard to believe :ROFLMAO: but many (and I do mean MANY) Ebay sellers intentionally ignore the shipping costs posted on their ads as a way to pump up the sale price and avoid fees. They'll play dumb until you bring it to their attention and then adjust the cost to a more realistic number. Last month I had to do this with an Ebay seller, brought shipping down from almost $200 to $49.
david3921
Wyoming, Michigan
Yeah, I'm wondering if the OP could get it down. It would ship from California to Alaska however.
There is a new local business that consolidates small package shipping and and gets the costs DOWN to only a dollar a pound.
I'm doing that for shipments from the UK to US. They gather a 30kg package, ship it slow boat to Virginia, then someone in VA USPS sends them across the US. Seems to be a substantial savings vs direct shipping, if you can be patient.
whateg01
How are duties dealt with?
Sumboodie
AK
Can confirm!
Yeah, still would be ~$250 which is about $200 more than I'm wanting to pay when I can build one for pretty much free.
AEAdam
SE PA
Instead of trying to fabricate a metal base or trying to weld the existing cast base, I wonder if you could bolt or weld some ugly square tubing, then build a form and cast a concrete base. It doesn’t have to be huge and the mass would probably help. You could probably incorporate casters.
I would get wrapped around the axle trying to repair that.
RoninB4
Under My House
-Using concrete as a machine base has been in use for quite a while. I've read of many shops/labs successfully using a type of concrete/cement to improve machine accuracy from the added mass. Seems like that would improve stability through mass to the fabricated frame/foot/base at a low cost.
AEAdam
SE PA
I didn’t know that.
RoninB4
Under My House
I didn’t know that.
-As reported on PM by a knowledgeable member who has an opinion I'd trust. Never tried it myself but always wanted to. Would probably only be valid in a climate controlled area to avoid thermal expansion of the machinery or provisions made for lateral expansion (perhaps).
Steve_P
I have a Delta 3/4 HP drill press that I bought new. The manual tells you to anchor it to the floor. If not, you're supposed to bolt the existing base to a larger wood base to guard against tipping. I built an additional plywood base for it, to their dimensions, or larger, out of some scrap that a friend had. I can measure it if you want to get an idea, but it sticks out quite a bit in the front. Basically, whatever you build needs to be larger than a cast iron base on another machine if you're not anchoring it; and if you want to be safe.
