Drill Press Cabinet Base
moonley
Edit: ****, I meant to put this in the general garage discussion forum, but oh well, hope it helps give ideas for those of you looking to do something similar...
I've been wanting to do this for a while now and finally got around to picking up a HF end cabinet and converting it to a base for my drill press so that I could get it off of my workbench and have some storage for drill bits and other items.
Since I always overkill everything I made some caster brackets out of some 2" x 2" tube and 1/4" steel plate I had laying around. I drilled and tapped the 1/4" plate, cut and recessed it into the steel tube but could have saved a huge amount of time and probably gotten the same result by ripping down some 4x4's and using lag bolts:
[URL=http://s985.photobucket.com/user/vanelsacker/media/IMG_20141123_134212.jpg.html] [/URL]
[URL=http://s985.photobucket.com/user/vanelsacker/media/26cbd06b-d9b0-462d-8855-c6dca102c03c.jpg.html] [/URL]
Rolls around pretty nice:
[URL=http://s985.photobucket.com/user/vanelsacker/media/IMG_20141123_162537.jpg.html] [/URL]
Then I got to work making a butcher block top for it and a couple other benches of mine by laminating together 2x3's and flattening them with a homemade router "skid":
[URL=http://s985.photobucket.com/user/vanelsacker/media/IMG_20141124_144346.jpg.html] [/URL]
When I got all done I was very happy with the result:
[URL=http://s985.photobucket.com/user/vanelsacker/media/IMG_20141129_153403.jpg.html] [/URL]
I'm a little sad about just how at home it looks next to my vintage Snap-On box. This is also my first HF box, and I'm just as sad that it is built better than most of the "American" brands in the big box stores today.
cheechi
Triad, NC
I like it. I have been wanting to start this exact project for a while now.
You don't use rails with that router sled? looks like it turned out fine in the end. Any pics of the bottom of the wood top? did you rout grooves to keep it secure on the lip or is the weight of the tool good enough for that?
xs650shawn
Hesperia, CA
Loved this idea, was going to do the same for my drill press, but found it was going to be too tall. Still think it is a good idea.
gtermini
Amity, OR
Very nice job. :thumbup:
I really like the way that HF cab looks with the trim removed on the drawer pulls; just like the old snappy. I would have never thought of doing that.
Greyson
GirchyGirchy
Central Indiana
Is the purpose of the router skid to slide the skid along the untouched wood so that it cuts into it at the same height? What do you do when you get to the end, is there some extra wood on the end for it to ride on?
Nice job btw!
zkling
Good job on the build. I went down this route about a year ago. The HF side box is the best bang for the buck in a side box, usually even on the used market. It is built better than almost all of the older common truck brand side boxes. It looks good next to your 7 drawer snap on.
theknurl
SoCal
Moonley;
rotate the drill press 90* clockwise to keep chips out of the drawers
rotate the disc grinder 90* CCW so you can use it
:beer:
taumac
Brooksville, Fl
Nicely done.[emoji106] I did something similar.
I thought about the HF side but I had this bottom laying around.
Have a good one, Gerard
Justind97
Ottawa, Canada
I am in utter envy of the butcher block! Came out exactly like what I want to build.
Is that two different types of wood that you used? How exactly did you get the alternating wood colour?
moonley
Nope, no rails and it turned out better than I expected. I had some very slight marring that came out easily with my belt sander, its not perfect but pretty darn good for the tools at hand.
I used my router to groove the bottom so that it would recess over the toolbox lip. To do this I used a undersized template and a guide. Then I used two lag bolts from underneath the toolbox top located along the centerline with the wood grain to allow the wood top to expand and contract.
Yes, here is a picture that shows what I did, I used a piece of plexi at the end to provide extra support and also to give some support when I got to the end, I then dropped the router bit flush with this spacer:
[URL=http://s985.photobucket.com/user/vanelsacker/media/IMG_20141130_185843.jpg.html] [/URL]
I countersunk the screws and added the plywood strips to each side for rigidity. When I surfaced the top the last 1/2" or so got a little messed up because of the lack of support but I trimmed all that off when I cut everything to size anyway.
Thanks, but the drill press is too long front to back to rotate it and the grinder won't fit with the sander if I turn it.
Nope, all just cheap builders-grade 2x3's. I did rotate each board so the grains cupped opposite of the one on each side (to try to keep the tops from warping over time), that may have some to do with why they appear to be different colors.
Thanks for all the support, I've gotten lots of ideas myself from these forums so I'm glad I can give a few ideas back.
azhatchback
That is bad A$$! I like that you used steel to do the caster frame! The entire project looks very professional.
