Vegaman_Dan
I've welded up a couple of clamps for my drill press that I could use for different purposes. I like the design, but there is an issue.
http://s1243.photobucket.com/user/flinters1/media/20130813_122243_zpsf7b7838e.jpg.html
Where the clamping bolt comes into contact with the work piece, it tends to cause either the clamp or the work piece to walk due to the rotating contact patch causing friction. My thoughts to solution are two approaches:
A) Round off the bolt at the contact patch to minimize the surface area- smaller surface area, less friction to try to grab.
B) Make a 'cup' with concave section to match a rounded off bolt like that you'd see on a C clamp. Problem is how to keep that cup with the shaft and still able to rotate.
C) Elminate the threaded bolt contact and replace with a toggle bolt setup to apply pressure- though that might be overcomplicating things.
Ideas? Thoughts? I love making my own tools and jigs.
