Drill press electric motor
Rod N
Keswick, Ontario
I bought an old Beaver drill press and when I plugged it in there was clicking and then smoke came out of the motor. Now nothing.
To replace the motor are all 1/2 hp 7250 RPM the same? it looks like it is a popular size for furnaces.
shawhite
7250 RPMs seems a little high to me but I’m not familiar with that exact DP model. Just match up the data on the name plate. Frame size, open or enclosed, RPM, HP.
lilredex
Toronto
Look for a 1725 RPM motor, lots on KIJIJI in the $20-30 range. Pictured is the 3/4 HP motor I put on mine. Stay away from the 3450 RPM units....too fast for a DP.
Packard V8
Spokane, WA
Most furnace/dryer/utility 1/2hp motors are resiliant mount sleeve bearing with 1/2" shaft.
Because DP motors mount vertically, the recommended power is a ball bearing motor which has no end play. It will take a while to wear out a sleeve bearing motor, but they're not best science.
Also, many DP drive pulleys are 5/8" shaft. Since you have no motor, you didn't mention having a drive pulley. Try to source a drive pulley having close to the same diameter steps as your driven pulley. It's not critical, just makes changing speeds easier.
Hint: since you'll be buying a motor, consider going 3-phase with a VFD; they're the cat's-*** for DP power - infinitely variable speed with no changing belt positions.
jack vines
R
Rod N
Keswick, Ontario
I found the service manual and my original specs were out to lunch.
1/3 hp
ball bearing
60 cycle, 1725 rpm
seber
Deep East Tx.
It is a light duty motor. The fact that it requires oil seems to indicate sleeve bearings. In any case, special duty means short life.
67carl
California
Not suitable for a drill press?
I can't answer your question but I'm also dealing with a DP motor search. This thread is very helpful;
Maui
Upstate NY
If you need a drill press motor (or a motor for practically any other machine) here’s my ad for American built electric motors for vintage machines:
I will ship, but shipping charges are high and it may not be worthwhile to you.
Maui
lilredex
Toronto
Looks like a furnace fan motor or other.... It will be OK for a home owners DP. You probably won't log more than 3-4 hours a year. Oil it up and run it for a few minutes, install and in a year's time, lay it over and add your ten drops. Use 3-in-1 oil in the blue can. Relax, it will be fine.
I have used that type of motors on various things, for fifty years, including several DP's without issues.
Milton Shaw
I adapted a 2 speed washing machine motor for my drill press, now I have 6 speeds. That comes in handy for metal drilling. Plus it was already set up for vertical use.
R
Rod N
Keswick, Ontario
I'm looking for a plug n play. I've only ever used 1 speed. lol
All of the used motors are making my head spin.
Lots of people out there have old motors that are un tested and they want $50 for them.
seber
Deep East Tx.
It's really easy to check a motor. Bring a cord with you with alligator clips or crimped rings.
Davefr
OR
The motor in your #8 post will work fine. It's not perfect but guys have been using replacement furnace and washing machine motors for years. A drill press is usually a low duty cycle tool. Instead of buying a new 1/2" step pulley you can probably just buy a 5/8" to 1/2" adapter sleeve and use your old pully if the bore doesn't match.
I've never heard of a Beaver DP but if it's a high end DP, then go the 3 phase/VFD route.
lilredex
Toronto
If you do as Seber suggests, bring a fused power strip with you so you don't fry the motor, by just blindly poking around.
R
Rod N
Keswick, Ontario
If I wasn't confused before, I am now.
Looks like the motor I need does not come with big enough spacing for the bracket.
Explains why my blown motor has a bracket welded to it and the only other one I've seen had a wood block between the motor and drill press.
R
Rod N
Keswick, Ontario
I'm seeing lots of 1/2 HP motors and my manual calls for a 1/3 HP.
Any chance of messing up my drill press with the larger HP?
Same 1725 rpm
exmaxima1
Midwest
Same 1725 rpm
Nope, all that matters is that you don't exceed the original speed and that it fits your pulley. BTW, a nice upgrade would be a 1140 rpm motor---you get lower spindle speeds for drilling metals and using hole saws. I put one on my Wilton (USA) drill press and now it spins down to around 280 rpm. Of course a 3-phase motor with VFD would be even better, but that would cost alot more (my motor was free)
R
Rod N
Keswick, Ontario
I'm finding I can buy a used drill press that comes with a motor, pulley, belt etc. for the same price as a used furnace motor. It would be a shame to scrap it after I took the parts though.
R
Rod N
Keswick, Ontario
consider a tread mill motor and controller,
sometimes, you'll get lucky and find a 56 frame motor that bolts right up.
I've heard this before, but every picture of a tread motor for sale doesn't look like anything that would suffice. Might need an electrician too, lol
bubinga
Let me see if I can find one on my PC I know I don't have it on my phone of the one that I used.
I can't promise but I might even have some controllers for sale if I have them here they might be in storage though I'll try to dig a picture up later.
R
Rod N
Keswick, Ontario
Interesting. I guess I would need the analogue controller, which means I need to buy the whole thing.
Lots of $50 treadmills out there but you can't see the motor mounts in the ads.
