Drill Press Key Storage
Where do you keep the Drill Press chuck key
  • In the designated storage spot (hole in the table)
    Votes: 29 24.8%
  • Some kind of string/wire/chain as a keeper
    Votes: 36 30.8%
  • Other
    Votes: 52 44.4%
  • Total voters
    117
doan
Frisco, TX
The other post about chuck key storage prompted this. My restored C150 is up and running. There is a hole in the table to store the key - IF you can remember to put it there. I have seen others that put it on a small chain, so you can always find it.
The chain guarantees it won't get lost or hidden amongst other tools, but I think it's a safety issue if you leave the key in the chuck and turn the drill on.
383 240z
Findley Twp. Allegheny Co.
I keep mine on a magnet on the head of the machine. It is on a chain as well. Takes a bit of training. The key is either in your hand, or on the magnet. Just like the lathe. Keith
Will S.
The First State
Mine has been tethered to the drill press stand for more than 50 years. Always right there, every time I need it.
Bigblue&Goldie
Mine is kept in the case my drill bits are in. Never have lost it, and it's easily accounted for.
Stephenw
Utah
I have a rare earth magnet stuck on the side of the head. I keep the chuck key there.
WILD-BILL
Brook Park Oh
I have a Craftsman DP that is probably about 7 yrs old at least. It has a dedicated clip style holder for the key to snap into. The key it's self has a springloaded pin in the end so it will push it's self out of the chuck when you take your hand off it.
Junkman
Northeastern CT
I haven't seen the key in about 10 years, so I haven't used the drill press in that time. I did a "restoration" of the drill press about 5 years ago, and painted everything, but never got around to wiring it again. I guess that I will leave that to the wifes next husband to deal with ...
senlow
Wheat Ridge, Colorado
I store my key on a magnet that's attached to the head of the drill press. Steve and Keith; do you hear an echo. Great minds think alike...
and I copied them. :lol_hitti
I used a chain on my old DP, the current one I'm using a magnet. Of the two, I prefer the chain.
Never turned the DP on with the chuck in place in near thirty years of use...
PugetDude
Superstition Mountains, AZ
I pop-riveted a 3/4" Conduit hanger on the front of the belt guard; just drop the key in. It's right in front of your face, so you can see it when you push the ON button
fordbroncodave
I have a craftsman 100 drill press, hole in the table is immediate right of the support column. since I am right handed it works well. spin the chuck with my left and insert key with my right.
I also store a few sharp small bits on the table for pilot holes directly in front of the key.
fourjeepin
Atlanta, GA
I like the retractable idea though I am a Magnet user. The ones from a hard drive are extremely strong and you can't accidentally knock it loose.
Provincial
Near Salem, OR
I voted in the designated spot because I have always kept the key for my Craftsman DP in the hole in the table. I picked up another DP the other day (a HF 20") and haven't yet decided where to store the key on it. I have two chucks for the HF, which complicates things!
bobcatdan
Kaukauna,WI
It just on top of the press on the belt cover. Like that at work and home. No problems losing the key since combined I use a drill about once a year.
Jim C.
I have a drawer in one of my boxes that's dedicated to various drill bit indexes and bit sets, egg beater drills, and drill press accessories. I keep my chuck keys in the same drawer.
Jim C.
kc-steve
Kansas City
My old DP has a spring loaded receptacle so when I let go it pushes the chuck out. I normally keep about a dozen different drill chucks in a small drawer in my machinist's tool box. But the DP has a specific chuck that can only be bought at Grizzly.
Steve
Jagmandave
Overland Park, Ks.
Mine goes into the chuck when I'm not using it, when I am using it it just lays on the bench near the press. The magnet sounds like a good idea, but I'd have to retrain myself, cause I'll be looking all over for the dumb thing at first! :confused::bounce:
View media item 35540
Davefr
OR
What's a drill press key???
Haven't used one in years. When I did this is where it was stored.
yuk
Living in quiet rural Missouri.
dont have a press but when i get one i will glue/epoxy a big ol speaker magnet to the it to hold the key and what few bits, etc... thea i will be working with at the time.
RCStocker
Indiana, California, Australia
Back in the 50's I worked in a small machine shop drilling thousands of holes a day. I put a round file handle on the key chuck. Not only did it keep if form being lost it was much easier to use because it had more leverage.
Remember you do not just use one whole to tighten the chuck. You go around to each whole and give the chuck a light twist. This makes sure the bit will not slip. I hate the keyless chucks unless you are doing woodworking then they are great. The ****** things slip no matter how hard you hang on if you are drilling steel.
Pox on the keyless chuck! LOL
Steinmetz
Washington State
Tighten all three holes. A representative from the Jacobs Co. told me this years ago. You will avoid those burrs that must be ground off the shank before the drill can be inserted into the drill index.
Davefr
OR
Quality keyless chucks don't slip any more then keyed chucks:
1. You need a quality keyless chuck like Albrecht. (vs. a low end Jacobs Multicraft)
2. You don't bottom out the drill in the chuck. You leave about 1/16". That way the geometry of the chuck will make it self tighten.
I have absolutely no slippage with mine drilling large diameter holes in metal.
The drill press belts will slip before the chuck does.
welder4956
Birmingham, AL USA
I like this idea!:thumbup: I think I have an extra file handle to use on it.
Mine stays in a drawer near the drill press with the bits. I have the same key on my 1/2" portable drill and lost the one that was attached to the cord. So mine sees double duty. One of these days I will get another one.
