Mickey O
- Location
- West of Chicago
- Price
- cheap
Prices do not include shipping. I have flat rate and regional boxes, send a PM with your zip code for shipping price. PayPal unless I've dealt with you before. $15 minimum.
When paying with PayPal use the regular payment method so you're protected and I can print shipping labels.
Indestro 3/8" drive socket set in metal case, ratchet, breaker bar (owners marks), 3/8 - 3/4 sockets (some extras), 3/8 Thorsen swivel, 13/16 spark plug socket - SOLD
Wright Tools 1/4 drive socket set Ratchet, 3" & 6" extensions, 3/16 - 1/2 sockets, 1/4 driver, metal case, UA made lifetime warranty (these are new unmarked tools that came in a Jensen toolkit) - SOLD
Vintage Walden Tomahawk hex drive socket set 1/2 - 15/16 (8 sockets), the box is just like the desired Walden 1/4" set without the divider, there is a small bump in the top easily hammered back - SOLD
Proto 5649 3/4 drive ratchet - $45 SOLD
Indestro Super 3275 1/2 drive ratchet, used shows some wear, works great - SOLD
Kal 1249 3/8 drive ratchet - $5 SOLD
Thorsen Action open head ratchet - $5 SOLD
Imperial Eastman or Walden (identical aside from name) refer ratchet $4 each
Vintage Armstrong 3/8 drive FAB-51 ratchet, missing little know on end of selector, works fine - $5 SOLD
Blackhawk GW9945 1/4 drive ratchet, excellent shape - SOLD
Vintage Japanese ratchet, very nice ratchet, works great - SOLD
Bonney 1/2 drive breaker bar - $8
Indestro 1/2 drive 3206 T-bar - $3
S-K 1/2 drive x 5" extension, well used - $3
KD Tools No. 27SG 1/4 x 5/16 ratchet with bits x2 - $5 each
Indestro 3/8 speeder, little flaking/rust - SOLD
Herbrand 1/2 drive speeder, very nice - SOLD
Hacksaw - SOLD
Parker Hacksaw (green handle) - $4
Always mini saw (red handle) $2
Hacksaw blade holder (black) $3
Klein hacksaw blade holder (blue) $5
Morse hacksaw blade holder with extra blades SOLD
Basin wrench (USA made, I think Chicago Specialty) - Pending
Vintage Mutli tool holder - $6
Tool rack/wrench rack (red) - $5 SOLD
Mustang 1/2 drive speeder - SOLD
Crescent 8" slip joint pliers, nice: $3 SOLD
P&C 7" (or so) groove joint pliers - $6
Diamond wire cutter, small chip on tip otherwise perfectly useable - $2
Taiwan 6" needle nose vise-grip style pliers - $2
4" nipper/end cutters, import 'm guessing, look unused - $1
KD Tools door handle spring remover - $1
Mini needle nose pliers - $1
Klein needle nose pliers, tips a bit rough - $2
Diamond needle nose 7" - $3
Diamond wire cutter $3 SOLD
Herbrand ratcheting flare/line nut wrenches 5/8" and 11/16" - SOLD
7/8" TAC tubing appliance ratcheting crowsfoot, 3/8 drive - $3
New Craftsman double box ratcheting wrenches, 11/16 x 7/8, 5/8 x 3/4, 1/2 x 9/16, 1/4 x 5/16 & 14mm x 15mm - SOLD
GearWrench (Ace) 10mm ratcheting wrench - SOLD
Par-X wrenches - $10 for all
Aven import midget wrench set - $3
Fleet short double box wrenches, 2x 7/16 x 38 & 5/8 x 3/4 - $5
MIT claw hammer - $2
Tack hammers - $1 each Pending
Armstrong adjustable pin spanner, tips ground a bit - $3
Kerosene heater igniter - $1
Mini USA made tubing cutter - $2
Rimac 14 cotter pin puller, new/like new $5 Pending
Jig saw blade, mostly AEG with pins 9pins can be ground off to use in regular jig saw - $4
Plumb Bob's, rough - $1 each
Stanley Shurform - $1
Lufkin 50' tape measure - $2 Pending
Lid L Looper - $1 Pending
Flywheel spinner - $5 Pending
Air Stream 1/4" mini die grinder, new - $10
3 rolls import electrical tape - $1
2 ton import bottle jack - $7
Suction cup thingies - $3 for both
4 piece holding tools - $5 life savers (I have 2 sets I'm keeping) Pending
Wen engraver - $2
Craftsman 1/4" bits and sockets - $1
Long hex set - USA made - $2
Malco C1 crimper, busted spring, still works - $2
Rally 12 volt impact with 2 flip sockets 3/4 x 11/16 & 13/16 x 7/8 - $8
'76 Buick Chassis manual - $5
Oxwall Japan adjustable wrenches, 10" and 8" - $8
Quali-Kraft slide adjust 8" adjustable wrench, Japan - Sold
Weil 10" & 8" adjustamatic wrenches, new, Japan - Sold
10" one hander, West Germany - $4 SOLD
40 + mostly USA made wrenches - $30
Hacksaw - SOLD
Wen engraver - $2
