strength_and_power
- Joined
- Apr 26, 2015
- Messages
- 1,476
14 years or so ago I bought a Grizzly G7943 14” 3/4hp drill press used. It fit the budget at the time and other than replacing the belts a few times, the return spring and chuck once, I’ve done nothing else and it has served me well, easily 100,000+ holes in various steel. I learned early on the value of good drill bits, cutting oil, taking the time to change to the proper speed, listen and watch the cut and adjust feed pressure accordingly. The $175 I paid for it was well worth it and it owes me nothing. It has gotten a bit sloppy on the run out, return spring broke again, handles have stripped, minor things that individually would be no big deal but collectively I feel like it is time to retire it and replace it. Grizzly still makes the drill press and I’m tempted to go with the same one based on my experience but I’d also like some opinions on other brands to check out. I’m open to a bench top or floor standing model, my previous was a benchtop on a rolling stand and that was nice for moving to sweep and such. Primarily I will be drilling 1/8”/11ga steel. I have access to a 20” floor drill press at work if need be. I had an import mill/drill for a bit but it wasn’t much of a mill or a drill so I traded it off. A Bridgeport mill or a clone is on my list many years down the road.
Thoughts?
Opinions?
Experiences?
Thanks in advance
Thoughts?
Opinions?
Experiences?
Thanks in advance
