Drill Press Stand
itgoze211
Keller, Texas
Long time lurker of the GJ and have spent many a smoke break perusing the Fab forum as well as a couple of others. To say I'm a novice at welding would be understatement but I love to learn and try my hand at new things. I've had a Craftsman drill press for several years and it's come in handy in many a project, but it's a whip to move around and get up on a workmate every time I need it. So I decided to build a mobile stand for it.
I tried my hand at joining the corners of the 1" angle stock with something I saw on a blog somewhere, but didn't exactly work the way I wanted (my general MO of trying to make something more complicated than it really should be).
The top of the stand is 2 layers of 3/4" MDF glued and painted for the press to mount to.
The legs and bottom frame are 1.5" square tubing and will have casters mounted on the bottom. My first thoughts were to angle the legs out a couple degrees to increase the stability and make the bottom frame a little wider since the press is pretty top heavy. But trying to fab the angles and bottom frame with just a chop saw turned out to be more work than I wanted. I was afraid that I wouldn't be able to get it square and remain somewhat level. So I opted to make the body all right angles. I figured I could cut some small 45 deg legs to weld towards the bottom to make the casters sit out bit. I'll add those pics once I have them cut.
Like I said...I'm very much a novice at welding. But am always willing to take any advice and tricks of the trade.
tarmy
Nor Cal
Here is an idea...made out of wood so I can store all my scrap cut offs from welding projects...
The STOP switch is a limb saver too. If you ever have a piece break away...you can smack that thing with your hand or head!
fiftyv8
Perth
I like some drills and other rotating devices that have had a VFD (variable frequency drive) added to the electrical circuit, there are many examples posted on YouTube.
The advantages are that you can run infinite speed settings and an electrical brake which when the stop is hit it really does stop immediately.
I run one on my home made bead roller and this is a device where you don't want over run when the stop button is hit.
The other advantage is that you can convert various power sources to suit a machine that you may not have otherwise been able to purchase and run in your workshop.
Single phase can run multi phase etc...
