Drill press to MagDrill adapter?
skipnay
PA
Has anyone used the drill press to mag drill adapter? This adapter lets you use mag drill bits such as annular cutters in a regular drill press. Wondering how well it works or is it a waste of time? Pro's and con's of such a piece? I have this drill press if it matters DRILL PRESS
https://www.fastenal.com/products/details/3164184;jsessionid=rSHa1f+GJzpbNPpt2dlhSkGq.443d7b2e-1555-3602-a586-c0d73327934b?r=~|categoryl1:%22601071%20Cutting%20Tools%209and%20Metalworking%22|~%20~|categoryl2:%22601075%20Holemaking%20and%20Drilling%22|~%20~|categoryl3:%22608586%20Annular%20Cutter%20Products%22|~%20~|categoryl4:%22608587%20Magnetic%20Drill%20Adapters%22|~
LXCam
I have a very nice quality 20" DP and I highly doubt the quill could handle the torsional/deflection stress of a annular cutter during the start of the cut. I use those in my Mill with no problem, but maybe your results will vary.
skipnay
PA
Haven't used one, but wouldn't mind trying. Hopefully you have a quality drill press, that will go slow enough, and have good quill support. That price seems whacked, cheaper here http://www.penntoolco.com/annular-cutter-holders/
I think I have a quality piece of equipment. The drill press will go down to 150 rpms. http://www.jettools.com/us/en/p/jdp-20mf-20-floor-drill-press-115-230v-1ph/354170 I see the one you posted is like almost half the price on the one I was looking at. I figured Fastenal was more but it's an easy place for me to find parts...
skipnay
PA
This is why I'm asking :3gears: I don't know and really didn't want to spend money if it wasn't going to work. I would be ticked if I tried it and it didn't want to even start it!!! What kind of drill press do you have? I posted what I have above...
2oolhound
BC Canada
I looked into this when I had a bunch of pipe notching to do. I ended up grinding them in with a round stone on the grinder.
I'm not sure what you want to do but if you could use a pilot shaft in the annular cutter like a counter bore bit it may help. For those one off jobs sometimes you can make do by ***** footing around a bit. Maybe even use a counter bore if they make one big enough.
LXCam
I think the slowest is 300 but it might be 150. To be honest I'd actually have to look. I rarely ever change the speed and leave it at its slowest setting.
