Drill Press wobble
Lucid Moments
Gainesville, Ga
I have a Delta 17-900 drill press that I inherited from my father. I don't use it often, but it really is nice when I need it. Recently it has started to wobble a lot when I use it. I don't have a dial indicator so I can't say exactly how much, but it is more than I am willing to put up with. What is my best route for fixing this?
GeoBruin
First confirm it's actually the spindle thats the problem. Swap out the chuck with a known good one or bypass the chuck all together and use a tool that fits the taper. If you still get runout, the bearings are usually the culprit.
Davefr
OR
Work your way from top to bottom with a dial indicator. Is it the spindle, arbor, chuck body or drill rod chucked in the jaws? Are you sure your quill is adjusted so it moves up and down freely without lateral slop? I'd also make sure the pulleys are in alignment.
Komet
WA
Clean and reseat the chuck would be an easy and cheap thing to do. You're going to need a dial indicator and a means of holding it still to positively identify where the problem is. Even a $40 combo one will suffice for this purpose.
L
Lucid Moments
Gainesville, Ga
I did take the chuck off and cleaned and reseated it and that hasn't fixed my problem. So I guess I need to pick up a dial indicator. I would like to get a nice Starrett or Mitutoyo but that just doesn't make sense for me. Is there a good mid range recommended one?
JradM
Alberta
Lee Valley on a budget. I'd probably try iGaging with a larger budget and if you want a digital version.
engineer2
Chicago burbs
I had a wobbly chuck. Taking the chuck apart and cleaning and lubricating it fixed the problem. There are youTube videos on how to do it.
Rusted Nut
Northern Arizona
Fowler Precision has some very nice affordable dial indicators and such.
Davefr
OR
For what you're doing, the cheapest dial indicator and magnetic stand will suffice. I'd get the non digital style because it'll be easier to observe deviation.
engineer2
Chicago burbs
You can buy an import dial indicator set with magnetic base for around $50.
You could also chuck up a long drill bit or metal rod to try to see where the wobble is.
I bought a Delta 17-900 new on clearance for $300 and it was a good machine for 25 years. Sold it for $350.
Bought the table-top version for $75 from a woodworker. That chuck had a lot of runout, rebuilding didn't help, so I replaced it.
Komet
WA
I like my cheapo indicator:
Probably the same one as all the others, came in a nice protective case.
