papabil
Hi. I would like to know aprox. drill speed for drilling 1/2 in soft aluminum plate.(fast or slow). thanks bill
don't have a Machinery's HandBook?
Get one, it has the answer for just about everything![]()
What is your drill, HSS? Co? point?
Usual SFM for Al in drilling for HSS is around 600SFM
600x3.82 / 0.500 = 4500 RPM approx
Thank you....WD40 does next to nothing well, LOTS of better alternatives out there.Something like rapid tap works WAY better than WD-40, why does everyone recommend WD?
Works pretty well for cleaning off old grease and oil before you put a new proper lubricant on it. But that's about it.
Thanks. fast with wd-40 worked very well. bill
WD40 is the best fluid if you're only going to have one. It's not the best rust buster, label remover, anti-seize, clock oil, contact cleaner or gear lube. But it is more versatile than any of the products that are the best at any of these tasks. -- but I do keep Tap Magic and Engine Bright around too.
Oh, yeah, and it's available everywhere.
Sometimes I'm almost tempted to suspect snobbery is at work ..." if it's really, really popular it can't be any good". IF there are any snobs out there, you're in good company. Tchaikovsky absolutely hated The Nutcracker Suite just because everyone else loved it.![]()
