Drill Speed Recommendations Craftsman 150 Drill Press? Full Manual?
DIY_Guy79
Tulsa, Ok
Hey guys, I got lucky, picked up an old Craftsman 150 drill press over the weekend. Has the Hi-Lo pulley in it as well. I'm trying to get together as much documentation on it as possible. Would love to find a complete manual for it, only found like the 1 page showing the speeds, and as well as a separate one showing the speeds for the hi-lo multi-speed pulley. Anyways, most importantly, I'm looking for drilling speed recommendations based on the drill press both with and without the hi-lo installed.
I had made a chart based on a newer model 15" Craftsman, going off the plate on the side. And just inserting the nearest speed. But I figure these are so popular, there's gotta be a better or even an official Craftsman chart floating around somewhere.
I attached the chart I had made based off the newer model Craftsman. While I think the first chart for the Hi-Lo speeds came pretty close all the way down the board. Unfortunately when it came to the stock setup without the Hi-Lo, there was nothing close enough to the lowest speed of 610 RPMs so just stopped at 771. I'm well aware 661 is going to be very usable, but I didnt know what should be recommended there.
Oh and here is the chart I originally went off of from the newer model Craftsman:
  • DrillSpeedRecs.pdf
JZiggy
Atlanta
When you get that center pulley set up correctly you'll be able to hit about 300rpm at the slowest speed
Zeus36
Ventura, California
See 11b30b4's speed chart here:
The post is here in GJ:
MSA Speed Chart
