drill weep hole in LB?
PoorOwner
CA
Yes i know that's a sprinkler pipe, just mocking up.
I have LB pointing UP towards a sub panel (bottom entry, exterior panel)
Is it ok to drill a couple small holes on the bottom of the LB?
mm08822
Technically not ok wrt the listing, but frequently done. One hole, 1/16 - 3/32" is plenty. Maybe even duct seal into the horizontal conduit.
P
PoorOwner
CA
On a related note, would you drill a hole on the bottom of back to back EMT run?
not saying I would, do you or know some people who does?
Bert_
NW Iowa
I never have, but I have debated doing it before. Most of the time I end up with a coupling so it isn't a problem. I have seen conduit split open from water freezing inside and seen it rust out at low points so it is a concern.
Stuart in MN
Minneapolis
Another option for conduit systems is to install a condensate drain fitting. Crouse-Hinds makes them, I assume the other manufacturers make them as well.
http://www.cooperindustries.com/con...d_drains/cd_series_ordinarylocationdrain.html
