lostsoul65
- Joined
- Apr 10, 2014
- Messages
- 17
Timbers are 3x4x8 and I am using them as a border around my yard. I drill a hole into the timber so I can hammer rebar and hold it to the ground. So after drilling the holes in the center I look on the other side and it’s about ½ off so I hammer rebar to hold them to the ground and they tilt about 10 degrees which won’t work because I have to nail another timber on top. So my question is could I measure the center from both sides and drill half way throw one side then turn it over and drill from the other side which should give me a straight hole?
When I drill a ½” hole throw the timber and hammer a 1/2” rebar you have to pound your brains out with an 8 pounds sludge hammer. So if I drill a 9/16” hole will that be too big to drive a foot of ½” rebar. Would it still be tight enough or should I just stick with drilling ½” hole?
