tpolley
This is probably a dumb question.
I've been drilling a lot of aluminum in recent years. I've noticed that the drill bit seems to always walk, or drift to one direction as it cuts thru the aluminum giving a crooked hole. It hasn't been an issue because I've always been pre drilling for screw holes, but last evening i was trying to drill an accurate hole and it ended up being crooked as **** because the bit drifted as it cut thru the 3/16 aluminum. The hole was right on my measurement on the side i penetrated, the opposite side it was g.d. 1/16 inch off.
Oh, and I've been using a cordless drill. Drill bit size in this particular example is #1, or .228, or just under 1/4". But this would apply to other sizes, also.
So, short of using a drill press and a vise, or taking the part to work and using the scotchman ironworker, is there a trick to drilling a more accurate hole in aluminum with a handheld drill? Should i pre drill with a smaller bit?
