drilling grade 8 bolts?
The Cobbler
anything I should know about drilling grade 8 bolts on a lathe?
I need to make some leveling bolts , 1" fine thread and all I can find is 1" grade 8 bolts. need to drill a 3/8" hole thru the center to set an anchor
Tks
BuffettFan
Central Illinois
I did this recently to make some threaded sleeves.
Went easier than I anticipated.
I faced the markings off of the heads, center drilled, then drilled and reamed 1/2" through, bored a 5 degree taper and finally parted off and faced both ends square and to length.
Facing and drilling around 350 RPM and parting around 100 RPM.
HSS drill bits, 80 degree facing insert, small triangle boring insert.
I may have some pics.
rsanter
visalia ca
Sharp bit
Go slow
Use oil
I have done that before on the lathe to make adjustable feet with screw on rubber pad on the bottom
BuffettFan
Central Illinois
if that's for me, it's cause the thread on the machine is fine already
There was another post that has since been deleted asking about the taper. I assumed it was referencing my original reply.
Have you had time to try drilling them yet? Sharp drill bits, low RPM and a slightly heavy feed will be your friends. Just don't let the drill bits rub themselves to death against the bolts. I drilled and tapped a pc of round stock and locked the bolt into it with a jam nut to chuck it up and not bung up the threads. Worked good.
matt_i
If you have access to a collet system that's the best way to preserve concentricity and not impact the existing part.
If you have access to NM-B wire scraps, simply strip off the insulation and wind up a coil spring of copper around the thread. Now you can clamp on the part and not impact the thread crests. Should stay reasonably concentric.
My goto pilot bit is a 5/32" for machine work. 120 deg spot drill, then the 5/32" pilot, and then I'd step right to 3/8".
T
The Cobbler
I was searching google for something similarly related & this 5-3/4 yr old thread popped up.
Never did finish this project, I started & it sits . I faced off the bolt heads and never got around to drilling & tapping.
I need a list , not a honey do list, a cobbler do list
:lol_hitti
Monza Harry
Windsor ON
:lol_hitti
Keep that pace up @ "The Cobbler" and you will be as fast at these projects as I am! :lol_hittiThat is almost 6 years to bounce back, I'd bust on ya' but that isn't even as slow as my top 3 slowest projects! Harry
